Water leak
Water leak
I have a 96 406 saloon which is collecting water in the boot. The nearside rear of the mat gets wet in the rain. It's not coming from the boot lid as it's just the mat. After heavy rain it pools in the corner and makes the trim surround it wet. Any idea as to where to look for a leak?
Cheers.
Cheers.
Re: Water leak
I had the same problem. It turned out that the water was coming in via one of the the tail lights.
You might want to check the spare wheel. Mine was swimming
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 710.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
Re: Water leak
That sounds like a plan. I'm abroad at the moment and don't want to start dismantling things so will check it when I get back. Stuffing newspaper under the mat in the meantime!
Re: Water leak
Just discovered I have water in the front passenger footwell too. This has been a longstanding problem I thought I'd sorted out (thought it was a coolant leak as the coolant needed frequent topping up) but now guessing not!
Re: Water leak
Hi,
Is the rubber seal that runs along the length of the sill still there & intact,
clumsy feet can dislodge it/damage it this in turn allows road spray to get under the doors & run
down in to the footwells
,another favourite is blocked up sunroof drains (if you have one)
2006 BMW e61 535d m-sport
run's for cover
Re: Water leak
dirtydirtydiesel wrote:Hi,
down in to the footwells,another favourite is blocked up sunroof drains (if you have one)
It happens when the car is standing for a while.
Where would I find the sunroof drains?
Re: Water leak
Search for (sunroof woes & cures with pictures).
It's well documented on here & you've been a member longer than me
run's for cover
Re: Water leak
I found the post. Thanks.
Any idea how I can remove the trim panels on the A pillars? The original poster says they are on clips but mine seem reluctant to move and I don't want to force them....
Re: Water leak
Quite simple, just pull some of the rubber seal away from the trim - then pull, start from the top. If you have an executive, be gentle with the sensors at the top.
There are some spring clips in he back of the trim, which locate into square holes in the pillar, these can be a bit stiff.
Re: Water leak
Nice one, thanks.GingerMagic wrote:Quite simple, just pull some of the rubber seal away from the trim - then pull, start from the top. If you have an executive, be gentle with the sensors at the top.
I'm abroad at the moment so will wait until I'm back in the UK before fiddling with it.
