Doser valves
Matcoupe80
Doser valves
Post by Matcoupe80 »
Hi. Any idea what the doser valves do and can they be removed on a 2.2 hdi?
rwb
Re: Doser valves
Post by rwb »
The air doser is a pair of butterflies in the air intake which:
* can divert fresh air to bypass the intercooler (this is why there are two). the intercooler is bypassed during DPF regen.
* throttles fresh air when the EGR is open in order to encourage exhaust gas recycling, and
* slams shut when you turn the engine off, this prevents run-on and makes shutdown a but less wobbly.
They can be removed but this must by accompanied by a remap as if you unplug the actuators then the ECU knows that something is up.
Search for "nico pipes" for the part you need to remove it.
Matcoupe80
Re: Doser valves
Thanks for the reply
