Factory info using VIN number ?
i remember doing this before but have forgotten how ..........help TIA
Re: Factory info using VIN number ?
It's on Service Box - http://public.servicebox.peugeot.com/ (it's free, you don't have to be honest...) or someone on here will be able to look it up for you if you post your VIN.
Yes, get yourself set up on Service Box - select your language ( box in the bottom right ) and enter your vin in the top left box - only need the last 8 digits.
Select 'characteristics' on the left and this will give the full specs of your car
vin. Vf38brfna8127358havent got logbook yet so think that's correct number...sunglare not helping
That vin comes up as invalid, you need better sunglasses..
Serial 406hdi licker
Because it's only the last 7 digits that are numerical on the post - one number missing...
Please double check and try again
vf38brhyf81329814 any better ??
Better.. here you go.
Vehicle characteristics
Vehicle family 406 (RESTYLING)
AS/RP N° 08934 89 2 0201
Warranty Start Date 07/06/2001
Engine serial number 10 DYFU 4029945
BER e2*98/14*0087*02
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 406 (RESTYLING)
SILHOUETTE 4 DOOR SALOON
TRIM LEVEL SELECTION PACK
ENGINE TURBO DIESEL DW10TD
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
INTERIOR TRIM TYPE VAN VELDE CLOTH "GT"
UPHOLSTERY COLOUR "FX"
GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
ENGINE (TYPE) EW/DW
OTHER BADGE HDI
BADGE WITHOUT BADGE
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 22X18
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) DEPOLLUTION MOTEUR SUPERIEUR L4 CEE 2000
SPEED SENSOR SIGNAL SENSOR HALL EFFECT
ENGINE (TYPE) EW/DW
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
EOBD SELF-DIAGNOSIS SYSTEM WITHOUT "EOBD" AUTO-DIAGNOSTIC
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION DEPOLLUTION TECHNIQUE VEHICULE L4 EURO 3
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 1 FAN 350W
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT W/O INJECTION VARIANT
Gearbox Transmission
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 77
WHEEL STYLE CORAIL ALLOY WHEEL
CLUTCH HYDRAULIC CLUTCH
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
DIFFERENTIAL (GEARBOX) SUPERIOR GEARBOX DIFF
TYRE (SIZE, TYPE) 195X65X15 H TYRES
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEELS
GEARBOX TYPE GEARBOX BE4R
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 22
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 23
SERVICE BRAKE ELECTRONIC BRAKEFORCE DISTRIBUTION
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
POWER STEERING FLUID COOLING SYSTEM WITH POWER STEERING OIL COOLING
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT VARIABLE SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
EMERGENCY BRAKING ASSISTANCE TEVES BRAKE SERVO
Body fittings
HORNS HORNS-HARMONY
AERIAL AMPLIFIED ROOF AERIAL
WIPER ARM FRONT BLADE WITHOUT DEFLECTOR
SIDE MOULDINGS (TYPE) PROTECTOR WITH CHROME RING
SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS L=50 + SIDE SILL
WHEEL EMBELLISHER (STYLE) CORAIL CAP
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT DOOR MIRROR WITHOUT ADDITIONAL FUNCTION
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING BONNET SOUND-PROOFING
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER W/O REAR SCREEN WASH WIPE
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
BUMPER BODY COLOUR FRONT/REAR BUMPER
MUDFLAP WITHOUT MUDGUARD
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES BODY COLOUR DOOR MIRRORS + HANDLES
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) DOMED DRIVER’S DOOR MIRROR GLASSS
REAR SCREEN WASH W/O REAR SCREEN WASH
SUN ROOF FIXED ROOF
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
WINDOW (TYPE) NON ATHERMAL WINDSCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT REAR BENCH SEAT SINGLE CUSHION SEPARATE SEAT BACKS
SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
REAR SEAT ARMREST WITH REAR ARMREST
LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP
RADIO TELEPHONE WITHOUT TELEPHONE PRE-EQUIPMENT
LUGGAGE COVER WITHOUT LUGGAGE COVER
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
AIR CONDITIONING WITH HEATER ASSISTED CONTROL
SPEED GRADUATIONS GRADUATION MPH
CONSOLE LONG CONSOLE WITH EBONY EFFECT TRIM
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
DASHBOARD EQUIPMENT DASHBOARD LARGE GLOVE BOX COVER, EBONY STYLE TRIM
INTERFERENCE SUPPRESSION RADIO INTERFERENCE SUPPRESSOR
MISC. INT. LAMPS MAP READING LAMP
LOAD SPACE TRIM TRIM BOOT + RR TAILGAT FLAP
INSTRUMENT PANEL (CHARACTERISTICS) WITH CHROME DIAL SURROUNDS
DOOR TRIM EBONY EFFECT DECOR
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLS REMOTE RADIO CONTROL WITHOUT CD FUNCTION
POLLEN FILTER WITH POLLEN FILTER
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT SUN VISOR SCREEN
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
HANDBRAKE WARNING LAMP WITHOUT PARKING BREAK INDICATOR
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT ELECT CONTR RR WINDOW LIFTER
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
COURTESY MIRROR DRIV OCCULT+PASS OCCULT W/O LIGHT
OIL GAUGE OIL TEMP + LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG DOUBLE FRONT LATERAL AIRBAG
PASSENGER AIRBAG PASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION) DRIVERS SIDE ELECTRIC WINDOW AUTO STOP
LOUDSPEAKER GRILLE (REAR PASSENGER COMPARTMENT) WITH REAR SHELF LOUDSPEAKER GRILLE
ON-BOARD COMPUTER COMPUTER
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
COURTESY LAMP FR+RE DOORS CONT - FR+RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SUN VISOR DRIVER’S+PASSENGER’S SIDE WITHOUT INSCRIPTION
RADIO RECEIVER "RD2" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARR+FR DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
AIR CON./TEMPERATURE REGULATION WITH REGULATION AIRCON/TEMP
STORAGE (OTHERS) ONE STORAGE BOX IN BOOT
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
INTERIOR PROTECTION WITHOUT INNER PROTECTION
SWITCH ELECTRONIC ANTI-THEFT KEY
COOLANT LEVEL WARNING LAMP WATER LEVEL WARNING
ANTIPOLLUTION MALFUNCTION WARNING LAMP WITHOUT ANTIPOLLUTION MALFUNCTION LED
TRIM ADAPTATION STANDARD GEAR LEVER KNOB
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL SPORT LEATHER STEERING WHEEL
FAN 1 FAN 350W
Electrical
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L2 400
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
MULTIPLEXING WITHOUT MULTIPLEXING
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION LCDV CREATED FOR INIT VERSION16
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
FIRST AID KIT WITHOUT FIRST AID BOX
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 HF PLIP KEY + 1 SINGLE MAIN KEY
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
General information
PRODUCT TYPE CAR
TRANSMISSION BVM5
ENGINE (TYPE) EW/DW
OTHER BADGE HDI
BADGE WITHOUT BADGE
Fuel supply-Engine
ENGINE (TYPE) EW/DW
FAN 1 FAN 350W
TRANSMISSION BVM5
ABS WITH ABS BRAKES
Body fittings
HORNS HORNS-HARMONY
SUN ROOF FIXED ROOF
Interior fittings
FAN 1 FAN 350W
Electrical
HORNS HORNS-HARMONY
Miscellaneous
thanks for that gents , help much appreciated , just got to get relevant bits printed
