Hi guys,
Can someone clarify where to plumb a boost line into on the hdi90.
As this has no intercooler do I tap into the intake manifold or is there an easier option?
Would like to know what my turbo is doing...
Thanks in advance!
Boost gauge install hdi 90
2001 HDI 90bhp - current daily
Re: Boost gauge install hdi 90
This is the diagram showing the turbo pipes.
If you have an air doser, that seems to be the best place to drill a hole.
Otherwise in the 90 degree hose no. 4.
Think it is best to detach the hose when drilling a hole in it, to prevent the debris from entering the inlet.
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 710.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
Thank you very much for your reply! This helps a lot.
I’m considering adding an intercooler so this also helps the pipe layout for me.
Here is a diagram of the extra plumbing you'd need:
Current "fleet":
Previously owned:
Previously owned:
The fan cowling and engine cover is also different - just something to bear in mind..
