Replaced doors / Central locking problem
Szmoryboy
Post by Szmoryboy »
Hi!
We have a 1999 406 RHY. I replaced doors from a 2002 RHZ and the central lock is not working properly.
the front lock motor connector in the front doors is not the same. Everything else works perfectly!
The old 5 wire
the new 6-wire
How can I solve how the lock works?
(Sorry for my english...I'm from Hungary)
Wul
Re: Replaced doors / Central locking problem
Post by Wul »
Is it not possible to use the old lock motor in the new door?
2001 406 D9 2.0i 16V 135 - planning to use it for at least 6 more years
1998 306 N3 1.8i 8V 103 - has been asleep for 8 years now
It's a bit tricky but I'm sure you could put the old wiring loom into the new door?
WillNZ
Post by WillNZ »
GingerMagic wrote: Sun Apr 04, 2021 9:26 am It's a bit tricky but I'm sure you could put the old wiring loom into the new door?
In my opinion, this would be your only option. The 2 cars would have different bsi's (which controls the central locking). Yours would be an early version, the donor the later version. My experience with these cars tells me that, unless you can find decent detailed wiring diagrams for either system, it is unlikely you will get it to work. Don't just try to make them work as you run the chance of damaging the bsi. Just put the wiring looms and central locking units from your old doors into the new doors.
Serial 406hdi licker :cheesy:
