406 sri turbo problems halting at speed and high revs
this problem is doing my head in you put your foot down in 3rd gear get to about 3 4000 revs the engine managment light will come on then the car will jam (halt stop ) for a second then will carry on going it also does this when you reach high speeds plllleeeeeaaaaasssseeee help me cheers pete
peter wiggins
- jameslxdt
get the fault codes read, but the favorite is the turbo control solenoid
had the codes read but
had the codes read but the code reader couldnt pick the car up (what a pain in arse)
peter wiggins
- jameslxdt
was it a snap on one or one of them ones of ebay?
what diagnostic socket does your car have? OBD1 or the 32 way brown plug?
- jameslxdt
there is a way to read the codes without any code reader with that plug, ill have a look in the book at work, you can buy a code reader for about £20 from halfrauds but it aint worth it really
oh and by the way, the snap on scanner is utter shite, i dont think ive seen it work on one car yet
would be utterly grateful if you could find out for me my email adress is annamariaowen@aol.com cheers pete
peter wiggins
- niz406
- Admin <BR>Turbo God
Re: had the codes read but
I had this, and I mean it was a proper pug / cit diiagnostic machine....... it cocks everything up! and you wonder why you have electrical probs lolpeterw1983 wrote:had the codes read but the code reader couldnt pick the car up (what a pain in arse)
Replacement ECU
It's over boosting, as James said....... good lad you! ( WCS ) Wastegate Control Solinoid
Your lucky most people that are buying tubs are ending up with siezed tubs !
- jameslxdt
i knew it, im always right these daysniz406 wrote: It's over boosting, as James said....... good lad you!
Well 'urry up and be right about how to read codes without a reader thenjameslxdt wrote:i knew it, im always right these daysniz406 wrote: It's over boosting, as James said....... good lad you!
