406 Dash board Lights - Definitions
Harshan
2.2 16v
Post by Harshan »
does anyone have a diagram which shows the dashboard indicators and the meanings / Definitions of them? (406 D8)
i got a strange indicator from yesterday onwards something like this .. when i step on the break pedal
[img][img]http://img252.imageshack.us/img252/9179/warnmo7.jpg[/img][/img]
Think that one says you need new brake pads. Or it could be an abs fault... Check the pads first - cheap and easy to check and fix.
Harshan
2.2 16v
Post by Harshan »
Thanks M .. but I replaced front pads last month.. and its non ABS.. I thought its the break assistance (the vacuum)
scrapheap
Post by scrapheap »
Check the little wires that "plug in" to the pads - these send a signal back to the dash when there is a circuit - ie. when the pads have worn so low that metal is conducting the signal.
2.1TD LX Cat C
No longer in use, and SORNED due to..
Steering leaking.
Back door stuck shut.
MOT and Tax out.
Baby on the way, so now have a 405 Estate
Any offers for the 406 ?
wes1001
Location: Sticky out bit, right on the tip of Kent, practically in the channel !!
Post by wes1001 »
That light defo means pads so i'm guessing a connector has come loose or as was stated one of the wires is earthing out and touching somewhere it shouldn't :?
