Electronic oil gauge with no "000000"s, sometimes
Sometimes my oil level gauge on my D9 flashes "min.. ..max" instead of displaying a solid min..ooooooo..max
It seems to do it if you start the car and start moving straight away.
Anyone else have this? The actual oil level is fine and never ever moves.
andythediver
Post by andythediver »
first time this happened to me i thought i had an oil leak!!
its if you park on an incline or the camber of the road is steep
oil runs away from the sensor
same way the fuel guage misreads if you park on a steep hill
I must admit, the few times it's happened has been on an incline :oops:
Do you know how the sensor works? it seems pretty accurate on mine reducing to one less 'o' when the level drops a tad.
jameslxdt
Post by jameslxdt »
its like a variable resistor with float switch, as the oil level goes down the float will sink producing a higher resistance thus alowing less voltage to pass through it and too the gauge
