Ok how do I remove it? I can see a plug on top of the reservoir which I assume is feeding the sensor. I need to remove it to clean it/replace it as the car is telling me its low when its not.
Brake Fluid Sensor
Re: Brake Fluid Sensor
its not that sensor that is causing the problem.... its the switch onthe back of the handbrake
it does it on mine its a common problem... try yanking the handbrake on and off several
times ... welly told me to do this and eventually it seems to have worked
Nice one, cheers puggy
i have this problem too, now that you mentioned it, normally happens when the hdanbrake is up...
let me try and see if it resolves the condition.
