dashboard lights
andrew1608
dashboard lights
Post by andrew1608 »
I have got a rapier 2lt 2001 model, i have recently noticed that the area where the rev counter is a bit dark so i suspect that the bulb has popped in that area, does anyone know how i would go about replacing the bulb, is it easy to access.
Re: dashboard lights
do a search or buy a haynes. 8 torx screws and a bit of levering is all you need.
andrew1608
i don't have either, do you know what size or torq bit is needed.
Just buy a small set of bits from your local maplins. The security bit set in a green rubber package is well worth the £5 they sell it for
old codger
Post by old codger »
:shock: No Haynes,torx bits or hex bits!! :shock:
Gonna be hard work on a pug without em.
Tiny Tim
Post by Tiny Tim »
Its a t20 IIRC.. if not T25. Not difficult at all. Had mine out about 20 times trying to get the speedo working (Bloody Bitron box lol).
andrew1608
is it just 3 screws to remove
