keypad /immobiliser problem
speediepug406
Re: keypad /immobiliser problem
Post by speediepug406 »
You didnt hit a pothole by any chance and pop the fuel kill switch in the engine bay.It beside the right hand turret and is black or red,push the button to reset the switch.Have a go it could be the little things that count,you can also decode the ecu to take the code out
spoke to main dealer who said it is because we have not changed the code number fom its factory set number
Sounds like bull to me. I'd suggest it's the keypad. Try searching on here for red and green
Whenever that's happenned to me I've disconnected the battery which resets the immobiliser. Definitely worth a shot!
jameslxdt
Post by jameslxdt »
have a search, ive told so many times about bypassing the keypad on a 1.9 td
