Fog Light Lense
sidmon1
Fog Light Lense
Post by sidmon1 »
Can the Fog Light Lense on a '96 406 be interchanged with another off another foglight. The only reason I ask is mine on my car is shattered but I have a replacement foglight, though the plastic bracket around the foglight is broken/cracked in places....hence I need to take my foglight off and just swap the lenses over....thanks.
1996 Peugeot 406 Executive 1.9 XUDT
Re: Fog Light Lense
I don't know without seeing it, it should be fairly obvious if it comes to pieces or not if you've actually got a broken one to inspect. You might have to distroy the lense of the one and the back of the other, then use something like epoxy to glue the two bits together.
sidmon1
Re: Fog Light Lense
Post by sidmon1 »
It doesn't look obvious. Theres a seal around the lense but there's no clips holding the lense to the actual foglight's body.....didn't want to start taking it apart and ruining it!
Re: Fog Light Lense
I thought it was already ruined!
Re: Fog Light Lense
i have 2 new ones i am going to put on my 406 . They are a sealed unit
looks like if you were very careful you could part them and re seal them :shock:
sidmon1
Re: Fog Light Lense
Post by sidmon1 »
steve_earwig wrote:I thought it was already ruined!
Not ruined, just has a broken mounting bracket which is fixable but would have preferred to have been able to just swap the lenses over.....never mind, I'll have to repair instead. Thanks for the info chaps.
