mjb wrote:Is there a distance threshold you need to cover before CC will re-activate? Do you need to turn the switch off and on again? I've never actually managed to successfully re-activate it, yet when I've tried to use it since re-positioning the switches, it's always worked first time every time. Just not second time...
Like everything else, it probably resets itself when the ignition's turned off, so you have to turn it back on again but if it's on it's on. They usually only work over a certain speed, distance doesn't come into it. I think your pedal switches are still buggering about
I've never driven a manual car with cruise either. I always wonder why they don't use the signal from the engine ecu on manuals, instead of the speed sensor, seeing as how the engine revs relate directly to road speed. This would get round being in the wrong gear, I presume they work this out when the revs get too high...
Cruise is nice but I sometimes found it a pain on GB roads; when it goes immediatly off yet again because someone else did something stuipd yet again, when the lorry I was overtaking on a dual carriageway decided to match my 75 mph and a queue formed behind me because I was too stubborn to fiddle with the cruise again, and the amount of cars I overtook 15 or 20 times, even though my speed never changed.
I've used it in the US a few times though, there it makes sense. The year before I came out here I went to the US with a mate, hired an suv and drove down from Virgina to New Orleans and back. You hardly even need to think, shove the cruise on, relax and listen to the stereo.
