lp pump
lp pump
does my 2002 90 hdi siemens have a low pressure pump in the fuel tank ( James ) ?
Re: lp pump
I don't believe the 90bhp siemens does.
Simple test is to turn the ignition on, with out starting the engine, and listen. if you here a buzzing/whirring noise from the rear (keep drivers door open) then it'll have a lp pressure pump.
1997 Honda Prelude 2.2 VTi
- jameslxdt
Re: lp pump
no LP on siemens, only bosch
