Battery charge and catayltic converter fault
jameslxdt
Re: Battery charge and catayltic converter fault
Post by jameslxdt »
sounds like a break in the wiring harness or the BSi is pooped
nimike wrote:what is the BSI
Built-In Systems Interface
nimike wrote:what is the BSI?
Expensive and fragile
Most modern alternators are 'intelligent' and only charge when they 'need' to so this could explain it?
if you have had this problem since changing the altenator i would
get it replaced under the warranty as it sounds like it could be faulty,
or did you have this problem before and thats why you fitted a new
altenator ??
nimike wrote:I replaced it because the last one was dead ... no charge coming out of it at all. I will get onto the motor factors this week and see what they say.
It may be worth changing the auxilliary belt as a matter of course just in case it's slipping :?
jameslxdt
Post by jameslxdt »
sounds like the wrong alternator
nice to hear a happy ending :) :)
nimike wrote:new alternator installed and working. Indeed there was a fault with the alternator, which is all covered under warranty.
Glad it's fixed! :D
