After a long saga with my 2.2HDi 406 including communications problems with the ecu's and not being able to reset faults etc. I have finally bitten the bullet and bought a Diag2000.
I have managed now to fix most problems and although the ecu can not be reset (pressumably a problem with the communications network on the main ecu) after three driving cycles the errors clear themselves once the issue is resolved
I only have one error left which is particlate filter pierced or differential pressure incorrect. The filter has been replaced and I can read the live data, the only problem is I can not find what these values should actually be for this engine anywhere . . .
Mine reads 0mb at idle (which I believe is correct) and 60mb at 4100rpm (i.e. with my foot flat to the floor). I have taken a spur off the air intake and managed to increase this up to 99mb and expected to get a filter blocked error but didn't!
Does anyone know what these values should be for the PSA 2.2 HDi engine (2000 to 2002), either for this car or a C5 or something?
Adrian.
2.2HDi Particulate Filter (FAP) Live Data Readings . . .
Adrian Paris
Paris Engineering Ltd - Computer Services And Repairs, Cornwall
