Air Con / Fans not working
PulsarJack
Post by PulsarJack »
Hi guys, got another problem with my fans (again)! I've done some searching of the other fan related threads, but i'm not sure if any really cover the same issue as mine. Basically, the external temp gauge has been all over the shop recently, sometimes reading over 40 degrees! :shock: Now, one particularly hot day (the glue on my tax disc holder even melted), I jumped in and cranked up the air con, and it worked for about 10 seconds then kaput. Nothing. I cant even manually turn the interior fans on. :frown:
I've had a look at the relays, and whilst one was a touch corroded (the bottom/middle one), I cleaned it up and put it back in. When I tried the air con, after about 10 seconds, the fans (both) kicked in, but immediately switched off and slowed down to a stop. This then happened repeatedly every 30-40 seconds or so. :? I've also tried taking the red plug off, but nothing happens. So, i dont know whether it could still be the relays (i might just get three new ones anyway), the bitron unit, the external temp sensor or the coolant sensor, or the fans themselves (unlikely imho).
Any help from anyone would be gratefully received!
Cheers
Jack
1 for economy, 1 for fun!
Re: Air Con / Fans not working
Quick question: Are both your fans running low speed?
No, scrap that, is this a D8 HDi? I only ask because mine's only got one fan, that set up sounds like the D8 one and it sounds just like my 2.1 TD when one of the fans packed up - full speed, nothing, full speed, overheating, shutdown, STOP light - but, if both your fans are running, I reckon you're either looking at the relays (specifically the one that runs them in series) the thermoswitch or the good ol' Bitron sensor, although judging by what you say the connections on the relays would be my first choice.
Huw
Post by Huw »
WHere did you find the air con relay? Just wondering if there is anything I can relate to my own thread.
Many Thanks
H
406silverhdi
Post by 406silverhdi »
my money is on ignition switch
where are you based
i changed mine this weekend due to this problem!
