Tyre pressures
Eric
Tyre pressures
Post by Eric »
I went to put some air in the tyres yesterday because they looked a little low and they were at 37 on the front and closer to 40 on the back already! :shock:
What pressure are they supposed to be at, I know it's a heavy car but I've always had 32-34 in all my cars previously.
Re: Tyre pressures
2.3 bar, or 34psi front and back.
Your fuel economy will drop now :lol:
Eric
Re: Tyre pressures
Post by Eric »
Welton wrote:2.3 bar, or 34psi front and back.
Oh well, the car might go round corners now and and avoid blowouts :)
Thanks for the info bud :)
Re: Tyre pressures
....Would also explain that floaty feeling you've had.
I mean the car - not you fella, unless you have had a floaty feeling? :lol:
Eric
Re: Tyre pressures
Post by Eric »
Welton wrote:....Would also explain that floaty feeling you've had.
Only when I drive after 6 Stellas :lol:
j/k
You might well be right, I'll give it a test tonight! :)
swiss
Re: Tyre pressures
Post by swiss »
I've been using 35. Ha!
The man with no car
darrenwall
Re: Tyre pressures
Post by darrenwall »
on the subject of pressures i put 34psi all round in my discovery only to read the owners handbook to find out i should be running 22psi in the fronts :shock: :shock: :shock:
just dip me in chocolate and throw me to the lesbians
Eric
Re: Tyre pressures
Post by Eric »
darrenwall wrote:on the subject of pressures i put 34psi all round in my discovery only to read the owners handbook to find out i should be running 22psi in the fronts :shock: :shock: :shock:
lol :lol: oops
puglover
Re: Tyre pressures
Post by puglover »
i remember reading a thread about tyre pressures on here.....think it was before the hack :roll:
i seem to recall something like it was ok to run the 406 at 40 psi without too much a risk and it helps your fuel economy quite a bit
but i might be wrong on this
