loosing water? 2.1td
locoboy
Post by locoboy »
My 98 2.1td appears to be loosing a bit of water.
I had a new rad fitted and have done approx 500 mils since that.
They had to bodge splice the bottom hose but i can not see any water seeping from the join.
I can see no max - min mark on the header tank so i filled it to the bottom of the neck.
After approx 200 miles my warning light was coming on intermittantly when the revs got up over 2500 or when i was going up a steep hill.
I filled it again to the bottom of the neck (1.5pints)
now after another 100 miles i bet i could get another pint in it but the light has not come on yet.
There are no abvious leaks that i can see,
Do you have any ideas on how/where to check?
also where 'should' the level be at in the expansion tank?
It may pay to get a propper bottom hose too but at £60 odd quicd its a bit steep dont you think?
Is there a recommended way of bleeding the system?
Many thanks
Re: loosing water? 2.1td
I did exactly the same as you; had to splice two hoses together for the bottom hose when I replaced the rad. It turns out that it was leaking from the splice only when the engine was up to temperature. I bit the bullet and got a new bottom hose for £42 after haggling & it's been fine since; now I've got a leak from the thermostat housing! :lol:
MDB929
Post by MDB929 »
Check the water pump: I was speaking to my mechanic friend last week, who is changing my cam belt and pump as I write, and apparently this is a very common cause of lost coolant. By all accounts if it's nipped in the bud the motor is good for 200k +. Mine's on 160k and still going strong :cheesy:
