Tools: Flathead screw-driver and a Torx Set
Take protective casing from handle with screwdriver then remove brass screw. Lift up window controls and disconnect wiring.
Take round plug where the mirror is off and remove screw underneath
Remove interior mirror casing
Remove mesh from speaker with flathead screwdriver. There is a tab underneath to poke it out. Then remove speaker
Remove oval shaped black screw cover and screw underneath
The rest is snapped on. Give it a yank out by grabbing the storage compartment. Dont force it though.
Lift up over the lip on the window and then its off.
Tip: Buy a Haynes Manual
Interior Door Card Removal
Re: Interior Door Card Removal
