Noisey engine on HDI 110
Pugman406
Post by Pugman406 »
Hi,
Had my 406 HDI for about 4 weeks now, sounded ok when i first got it, but ive noticed over the past two weeks or so, the engine has become very loud and tappety.
Does anyone know what could be causing it to sound like this and is there a a cure?
Thanks in advance.
D9 2.0 HDI, 406, GLX, 110
Re: Noisey engine on HDI 110
Same with mine. Does it go quiet over about 3,000 rpm?
Pugman406
Post by Pugman406 »
no its the same all the time, i dont have an engine cover on the top, not sure if that wud cut the noise out a bit?
Pugman406
Post by Pugman406 »
actually yea i think it does clear, cos only hear when its stationary or at low speed. duh
If it does then it's the injectors (apparently), mine are noisiest when cold. The other thing to worry about is the crank pulley...
The bottom pulley will give a nasty metallic clicking sound at low revs which rises and falls according to the revs, tell tale signs of a failing pulley are a brown dusty build up in the area and/or shiney metal flakes around the area and on the sub frame underneath. Once it get's near the end it's an unmistakeable horrible sound which tells you something is badly wrong down there :shock:
The other noises the HDi make is a clattery sound on acceleraton through 2000 - 3000 rpm, which promptly dissapears after 3000 rpm. This has been the subject of great debate on here but is generally considered "normal" although most probably never left the factory like it :| some say it's wear in the injectors but if the car generally runs well and gives decent economy then this would be an uneconomical repair to do.
Pugman406
Post by Pugman406 »
ok thanks for the info, think the pulleys were fine, just fitted new fan belt at weekend, as the old one was squealing like a pig!
Pugman406
Post by Pugman406 »
Well i took it to Peugeot today, they had a listen and they also said its the bottom pulley, they quoted £147 just for the pulley, obviously im not going to be paying that amount of money, i can get one online for £70 delivered! also got a new handbrake switch for £2 odd, fed up of it bleeping at me lol.
Thanks for everyones anwsers tho, much appreciated! :wink:
maglite
Post by maglite »
Hello, something strange happened to my D9 today. I started it this morning and it seemed louder than usual. I thought it was because of the cold start, but the noise did not go away after reaching 90 degrees. I'm getting like a clanky noise. I'll try and make a recording and post it up if I can.
Bottom pulley?
Starts as a cold weather tick then becomes a loud smacking clanking noise.
look for a brown dust around the area and the noise should rise and fall with revs.
I was thinking that and to check the belts too. Incidently, it's only 3 x 10mm bolts and a nut to get the top cam belt cover off, much easier than the 2.1 :frown:
maglite
Post by maglite »
Thanks guys, you were spot on! I managed to get a replacement pulley from GSF for around £45 and just finished changing it. What a headache.. Now all I have to do is fix that hole in the flexi pipe! :frown:
Pugman406
Post by Pugman406 »
Well i hope it lasts longer than the one i bought on flebay!
My original pulley lasted 145,000 miles, the replacement about 25,000. :evil:
Draw your own conclusions :roll:
Pugman406
Post by Pugman406 »
mine didnt even last as long as that, thats why i ended up gettin an original part!
