headlight washers - how easy
steveleyland
Post by steveleyland »
How easy is it to retro fit headlight washers ? do any models come with it standard and would the bumper fit on 2.0 SE HDI estate ?
Steve :?
Re: headlight washers - how easy
Something to read.
I guess it's the usual case of getting the BSI to play ball. You could get all the parts out the breakers but then it's off to the stealers for some wallet emptying.
steveleyland
not looking good then if bsi involved is that peugeot speak for bull sh*t interface :lol:
Maybe you could do it the old-fashioned way, using two relays - the first supplies power to the second when the headlights are on, the second supplying that power to the motor when the windscreen squirters go. Looks like you'd still need another bumper though, unless you're extremely handy with a jigsaw...
steve_earwig wrote:Looks like you'd still need another bumper though, unless you're extremely handy with a jigsaw...
...and have the ability to make a washer mount...
Need a bumper, nozzles, tubing, pump, new water bottle as well as the electrical/electronic side of things. And things will be more interesting if you've got an estate as there's already 2 pumps attached to the bottle
Nope, just the one - to wash the back window it runs backwards 8)
steve_earwig wrote:Nope, just the one - to wash the back window it runs backwards 8)
Could swear I could run both at the same time...
steveleyland
guess it will stay standard hehehe
By far the easiest solution :wink:
