Ignition timing and smoke
sollyboy
Post by sollyboy »
Hi Pug lovers
Waiting to get my clutch fixed on Wednesday should be straight forward I hope ....?... but when I last had my mot done back last year in December at the stealers , I though I would have problems with the smoke coming out the back (dark grey), passed the mot no problems with the smoke test well under the problem mark , but remember asking the reception guy to ask the mechanics about the haze of smoke coming out the back, noticeable on the motor-way with the car behind shining its lights through the exhaust smoke , I lost the paper work from the garage but I do remember it saying something about checking the Ignition timing to do with the smoke. The fuel economy seems ok and the power is still there. A mechanic friend of mine said to take it to a diesel specialist and get the ECU checked. Can anyone shed some light on the dark grey smoke problem , car runs fine apart from the stiff clutch pedal, but that should be fixed come Wednesday fingers crossed ,99, 2.0 hdi 173000 miles. All the best Sollyboy
Re: Ignition timing and smoke
Stuck EGR valve?
sollyboy
Post by sollyboy »
Stuck EGR valve.....? So how do I release the EGR valve , I've seen some posts on the forum that say to give it a clean out . Is this a easy job to do ? will check my mates Haynes manual tonight ? would clogged up EGR valve cause the engine to be a bit on the smokey side ? Cheers all the best Sollyboy
poddack
Post by poddack »
Stuck open or closed?
Sorry if it's a silly question.
Hmmmm, straight 6 goodness!
You know what - I'm going to be good at all this now :lol: ....
I can say only one thing here - my EGR was stuck open (leaking) have a sniff around it and you'll smell it! my car used to smoke quite a bit in car headlights behind me but with the new EGR the smoke has gone, and I mean really gone :shock: I can't even 'make' it smoke now.
sollyboy
Post by sollyboy »
I'm going to have a look at now to see if it is stuck open ( not sure what stuck open will look like ) but Lets have a look . Can it be repaired by just cleaning it ? , and the most important thing is how much will a new ERG value cost ?? Cheers all the best Sollyboy. One more thing just got the clutch done £250 parts and labour ( swansea ) nice soft pedal .
