Door plastic
redfar
Door plastic
Post by redfar »
Hi all,
I have a peugeot 406 phase 1 and I have the plastic or pvc that is near the window is peeling off can some some one tell me what is this plastic called?
1.9td 1996 D8
jimmartin1
Re: Door plastic
Post by jimmartin1 »
If its the strip on the door pillar that you are talking about then i picked one up in the peugeot dealers for around £4... I just aked them for exactly that :o
Re: Door plastic
Strip on the door pillar? What strip on the door pillar?? Hi Redfar, if you mean the plastic film try "window moulding". Time you signed yourself up to Service Box. Anyway, you should do what I do when I go to Peugeot here, drag the guy out, point to it and say "ug", normally does the trick :oops:
jimmartin1
Re: Door plastic
steve_earwig wrote: Anyway, you should do what I do when I go to Peugeot here, drag the guy out, point to it and say "ug", normally does the trick :oops:
Saying strip on the door pillar, getting a funny look and then dragging the man out to show him what i actually meant was my solution... So your not far wrong steve :lol: :lol:
