New battery, but do I need to take precautions?
Re: New battery, but do I need to take precautions?
I aint never heard nuffin like that before :?
I changed my battery and literally just...changed it! no drama (mine is an ancient 1999 though).
I would recommend having the doors and windows shut for, say, 20mins to let the BSi go to sleep but even that's getting a bit nerdy.
Why don't you ring a couple of dealers first?
supafrisk wrote:One of the guys who has changed his battery (2002 110bhp HDi estate) told me that after he'd fitted the battery that his key no longer centrally locks his car and he has to do it manually.
That sounds like the key lost its pairing to the car, there is a procedure for resyncing it again, I'll dig out a copy. It's on here somewhere too.
I'm sure I've seen a post on here (or somewhere else maybe?) about reconnecting a battery to find there's some electronic damage. With these thoughs in mind I've not disconnected the battery on my D9, just in case, but I'm not happy about it.
Talk to Peugeot? Or someone that knows what they're doing :roll: Actuallallally, I was wondering if I could attatch my welding surge protector as I dis/reconnect. :?
jasper5
Post by jasper5 »
The most important precaution to take when replacing the battery, is to keep the electrical system alive whilst the old battery is removed. This should be done whatever the vehicle.
I use two wires with crocodile clips and an old spare battery, connect the clips to the battery terminals on the car, then to the spare battery, then remove the faulty battery, replace it and remove the clips.
This always ensures that you never lose any codes or interfere with any electrical item.
This is my first post by the way, so, hello to everyone. :)
An even better answer for you supa!
Yahoo Answers wrote:Should work when you put the new battery in. You would not have power to operate the door solenoids with a dead battery, but when you install the new battery the door locks will work. The remote fob codes are stored in EEPROM memory, ie the car will still remember the codes even when power is lost. Good luck!
jasper5 wrote:The most important precaution to take when replacing the battery, is to keep the electrical system alive whilst the old battery is removed. This should be done whatever the vehicle.
What a spiffing idea!
Welcome jasper!
Welcome Jasper! :)
turbolag
Officer of the law!
Post by turbolag »
The answer is simple - buy a battery saver and plug it into the fag lighter beofore you start, so sufficient current is maintained in the various ECUs etc to give you time to swap 'em over.
Easy, eh?
jasper5
Post by jasper5 »
Thanks for the welcome :)
I used to have one of those that plug into the 12volt socket/fag lighter, the down side is that some cars do not have a 12volt/fag lighter socket, and some of the sockets have unreliable connections or don't work, for whatever reason.
Wires to the battery with crocodile clips are foolproof.
turbolag wrote:The answer is simple - buy a battery saver and plug it into the fag lighter beofore you start, so sufficient current is maintained in the various ECUs etc to give you time to swap 'em over.
Easy, eh?
I was just about to say that myself. They're just a few quid from Halfrauds and run off a 9v battery
Make sure yer stereo's off first though ;)
I think I read on here, (or somewhere recently), that there are two alternative fuse positions for the fag lighter - one that keeps the socket powered all the time & one that goes off with the ignition switch. Pay to check befoere disconnecting battery.
jasper5
Post by jasper5 »
Yes, I know that the 406 has the clamp-on type connector, but there are small type crocodile clips that will fit on to an exposed part of the terminal, you could always strip a piece of wire and wrap it round an exposed part of the terminal, then connect the clip to a bare piece of wire.
I know I'm new to this forum, but I do know what I'm talking about, I'm a motor trade professional, in business for the last 28 years.
Yes, I own a 406 HDI....also an Expert HDI van.
supafrisk wrote:Plus it's dark outside and I might get eaten. :supafrisk:
:lol: :lol: :lol:
Greetings Jasper :cheesy: I have done something similar (to preserve a coded radio) with 2 lengths of 2.5mm copper wire, strip off the end couple of inches, once round the terminal and twist so it's nice and tight. A bit thinner than croc clips methinks. Just don't get them confused!
jasper5
Post by jasper5 »
supafrisk wrote:
jasper5 wrote:Yes, I know that the 406 has the clamp-on type connector, but there are small type crocodile clips that will fit on to an exposed part of the terminal, you could always strip a piece of wire and wrap it round an exposed part of the terminal, then connect the clip to a bare piece of wire.
That's not the problem, it's getting the clamp off and then finding I can't get the blasted thing onto the new one!! (Apart from the fact that I haven't got a spare battery. I did have a shiny brand new one on the 406 coupe, but then some daft tw@t decided to get legless and write it off to upset me :evil: )
OK, no problem.
You could use a friend's/neighbour's car connected via jump leads to the clips/wires then check If the terminal will fit by lifting off the terminal, then measuring the size of the battery post that the terminal connector is being fitted to and comparing your original battery post size.
Failing that, ring up your local battery supplier with the number off the battery you intend to fit and ask if is compatible, better still, get the correct battery for your car....the number will read something like 075.
Thanks for the welcome, Steve :)
supafrisk wrote:Oopsie... :oops:
Base op nicked the battery off me that I bought last week for his Pajero.
I went out to the car this morning to start it ready for the school run and it was flat :roll:
So flat the damn thing wouldn't lock off the fob :(
Now I have the fun of trying to start it so I can go get another battery.
And I have the damn roofers arriving tomorrow morning :evil:
Oh gawd! You'll have to swap them back again & give him your flat battery! :supafrisk:
