bulb change in heater control display
dantae
Post by dantae »
hi all thanks for the help with the speedo,can any one tell me how i change the display bulb in the heater control display, thanks
Re: bulb change in heater control display
dantae
Post by dantae »
thanks for that but my car does not have a trip computer, also how do you get the radio out, thanks
If there's no trip computer you should have a tray that fills the hole. Just pull that out.
To get the radio out; you need 4 kebab skewers or screwdrivers that fit the holes on either side.
Push these right in to release the clips & you can wiggle the radio out. :)
dantae
Post by dantae »
dont have a tray there, all thats there is the display for the heater controls, do the exutive have a trip computer
What do you have next to your heated rear windscreen and hazard lights buttons then?
dantae wrote:dont have a tray there, all thats there is the display for the heater controls, do the exutive have a trip computer
Ok; as mjb says you should be looking at the row of buttons above the climate display. Yes you should have a trip comp/temperature/radio display unit. If not take a photo and post it here!
dantae
Post by dantae »
thanks guys for the help with the bulb change in the heater control display, i thought that the display by the hazzard swich was just the radio display, but when i put it back in all things lit up, so can any one tell me how the trip computer works
dantae wrote:can any one tell me how the trip computer works
A Bosch ECU and LOTS of re-wiring!
And don't we know it! :roll:
