Wobble feeling in car when engine revved slightly
adam03031980
Post by adam03031980 »
Ok update from my last thread my car wobbles when it is slightly revved now i put in injector cleaner but no difference, i cannot hear any strange noises, anyone got any ideas.
Re: Wobble feeling in car when engine revved slightly
The original thread, for those of us without total recall :roll:
I presume you checked the engine mountings. My HDi does something similar and I know it's because it's lost some compression on a couple of cylinders (it's also developed a squeek from somewhere now, just one thing after another :( )
Leak off and compression tests, off you go.
adam03031980
Its confusing me as this happened when cold but i just went out in it and it was warmed up and seems to erradicated most of the wobble now warm, in the previous thread the DMF was mentioned but i would have thought this may be constant if it were that as a problem. Where is the lower engine mount located as i have nevere looked for it can you see it from the top or will i have to get underneath.
See comments in zour previous thread about blipping the throttle and seeing if zour engine moves. )damn, wrong keyboard :x =
