Couldn't see anything else amiss and car was driving normally. I considered stopping, turning it off & re-starting, but with some fog, temperature of -3, rumbling tummy & an appointment with some beer later, I decided not to stop in case it wouldn't re-start.
Stopped outside the house, turned off, restarted, eml light stayed on & message 'Anti Pollution Fault' on MFD
Tried another few times, last night & today - still the same.
Now I'm hoping it's not a blocked FAP, (no blocked filter message or warning light).
Not the Eolys aditive, (no diesel additive low message & anti pollution service carried out about 30,000 miles ago).
Not the differential pressure sensor, (understand this triggers limp home mode if faulty).
Set about checking vacuum valves, pipes, reservoir, sensor connections etc - no difference.
Checked air filter:
Looked pretty manky so changed it - no diference
Set out to find someone with a code reader and
Been for a few 5/10 mile runs since & still Ok, so fingers crossed.....
