Clutch Cable???
angrydave
Clutch Cable???
Post by angrydave »
Hey, ive just bought a clutch cable for my mk1 406 as its been diagnosed with a really dodgy cable :P. Just asking really to find out is it easy to fit diy style or is it a garage job... also how long does it normally take ???
Thanks very much
David
Peugeot 406 1.9 TD LXS Estate yoooooooo
djheath
Re: Clutch Cable???
Post by djheath »
On my mk II it took about 30 minutes. Its not a bad job, worse part is trying to pull the cable behind the pedal assembly and clip it on the pedal. Lots of bending down in weird positions to try and get your head under the steering wheel.
Just make sure the car is well supported on axle stands when you are under the vehicle.
