hi i have just bought a p reg 406 1.9td sometimes the indicator light on the dash works sometimes not
sometimes the speedo works other times i have to tap the dash
also are the headlights suppose to stay on when i put my full beam on i didnt think they would
There's loads of info on here about dodgy connections on the instrument panel, usually dry joints on the PCB. Use the search box on the top right of the page...
Headlights, yup the dips stay on with the main beams because the 406 uses separate bulbs for dips and mains. If you had a lesser car with one dual filament bulb they'd go off
Welcome roady!
I've had to resolder two different 406 dash clusters, similar faults as yours and the speedo getting stuck at 40mph
