The drivers door on my 02 registered 406 appears to have moved slightly forwards. I would like to loosen the hinges and move back about ¼ -½". This would also allow me to set the door slightly further out, at present there is a slight step between the drivers door and the rear door and the bottom of the door is set in deeper than the top.This does cause a fair bit of wind noise.
I have a suspicion that wind damage may be the cause. (I'm just lucky that I don't own a trailer)
Is there a way to get access to the hinge bolts easily or do I have to remove the front wing and front valance?
Any advice would be appreciated, especially on removing the front wing if necessary.
Many thanks guys!
