WD40 straw went for a stroll
swiss
Post by swiss »
Hey geezers and geezerettes.
My clutch pedal has developed a creak- sounds curiously like a frog, in fact - and I want to WD40 the sucka.
But recently, tragedy struck - my red straw went missing! It seems to have fallen off while I was oiling the boot lock and then made a run for it. The wee red bugger was nowhere to be seen.
So, keepers of knowledge and menders of dodgy French motors, is there anywhere that'll sell me just a straw? Or do I have to buy a new can to get one?
:arrowd: :arrowd: Kitten! :arrowd: :arrowd:
The man with no car
Re: WD40 straw went for a stroll
I'd say nick one from a can in Halfords but I see the straw is now a built-in job. I loose them too... :cheesy:
jasper5
Post by jasper5 »
Use the insert for a biro, just squirt out the ink, or poke something in to take out the ink.
Pinch one Tom! :supafrisk:
I much prefer the cans with the built-in straw. I ain't lost one yet :lol:
swiss
Post by swiss »
Good suggestions, both the pinching and the bodging (I'm always up for a good bodge). What do you guys mean, built in? Mine was taped to the can, same way it's always bin...
The man with no car
eoin27
The Irish 406 addict
Post by eoin27 »
They're buggers for sure and seem to 'ping' off in any direction.
I remember asking Mrs Welly if she'd seen my little red straw once and she said she though it away thining it was one of the kids drinks carton straws on the floor :roll:
These days I'm a lucky man and am the proud owner of not one, but two straws 8)
Friday morning speak perhaps :roll: :P :P
What are you going to spray? Don't spray inside the master clutch cylinder as WD40 will just dry it out and the creak will come back. Use some Molykote O-ring grease for that.
It may be good for cleaning and un-sticking corroded things, but WD40 is a terrible lubricant. Use grease.
It's not meant as a lubricant, although it's good for spraying on stuff if you need to know they need lubricating, then you lubricate it properly
swiss
Post by swiss »
Well, I was thinking of spraying the hinge and pin, or whatever it is, on the pedal inside the cabin, under the column. I read a thread here whereby a chap sprayed his and the creak went away.
It might be something else entirely, of course, cable needing changing or some other mystical rite. But, well, try the easy things first :)
The man with no car
swiss wrote:Well, I was thinking of spraying the hinge and pin, or whatever it is, on the pedal inside the cabin, under the column. I read a thread here whereby a chap sprayed his and the creak went away.
...for 30 seconds
Seriously mate, get yourself a tube of grease. It's not expensive and it won't make a mess of your master cylinder :lol:
swiss
Post by swiss »
Hmm, well buying grease is certainly on my list of things to do, somewhere under 'get money to buy grease with' :p
Right, come pay day I'll head down the grease shop. Recommended brands/grades for general use?
The man with no car
