406 Clutch and Gearbox
Pob
Post by Pob »
Hi all,
Is there any difference between a Turbo and a 2.0 gearbox? I was wondering what difference's if any between the two regarding clutch plate/flywheel diameter.
Many Thanks,
Dan
alladdin
Re: 406 Clutch and Gearbox
Post by alladdin »
Pob wrote:Hi all,
Many Thanks,
Dan
yes a 2.0 gearbox is much larger than a turbo. :lol:
sorry ive been drinking :P :P
Gear ratios. Each box is geared to match the engine output, put the wrong box on and you'll kill the performance
alladdin
Post by alladdin »
ratios between petrol engines should be broadly similar. a turbo engine will produce much more tourque tho so might well be beefed up and have a larger stronger clutch. also since the diff is included with the box you have the overall gear ratio to consider. a 3.0 turbo will normally have a taller ratio than a 1.8
alladdin wrote:ratios between petrol engines should be broadly similar
The 2.0 turbo is a low revver so the gears will be far too long for the non-turbo petrol 2.0
Pob
Post by Pob »
Does the 2.0 gearbox/engine use the same size clutch plate and flywheel as a 2.0 turbo? The reason I'm asking is that I'm putting a turbo engine in a 205, people use a Mi flywheel and clutch so it fits a 205 gearbox. I was thinking of using a 406 gearbox so I can use the standard size clutch rather than a smaller Mi one as they tend to give up after a while. As I carn't use a turbo gearbox as its hydraulic, a 2.0 gearbox is cable so it should work.
Thanks,
Dan
alladdin
Post by alladdin »
you will probably find they are similar. the taller gearing is due to the diff ratio.
are the ratios in a haynes these days ? i doubt it.
as for clutch , look at the diameters, bigger is better. i have no idea which bits mix /match tho.
