twin cooling fans
twin cooling fans
ive just joined the 406 forum so hi . ive just bought a r reg 406 2.0i glx . i am having touble with the fans not working when the engine is hot . i have changed the briton senser , have shorted the switch and still no joy is there anyone who could give me some advice . thanks.
- mjb
- Site Admin
Re: twin cooling fans
Warm up the engine then pull the plug off the coolant temperature sensor. With the ignition on, the fans should run at max speed. If the dashboard temp display drops to zero you've pulled the wrong coolant temperature. If one fan fires up then you've got a dodgy fan or relay, and that will prevent any operation on either fan at low speed.
i think it must be a faulty fan motor because i can get the fans to work. when i disconect the wireing plug from the loom i can hear the relays chattering.
- mjb
- Site Admin
last check then's to find the power connectors for the fans and check for the all important 12v
