glove box removal
glove box removal
anyone know how to remove the fixed part of the glove box? after removing one in a scrap yard i see there are 2 screws that are very inaccessable,how do you get these 2 screws out?
Re: glove box removal
It should be helb in with a couple of pins.
I use wire/side cutters to slide mine out
1998 2.1d executive
Going from my (notoriously bad) memory, it's the hinge pins that you need to remove. Slide them in towards the centre of the glovebox to remove
i know ho to remove the lower part,i need to know how to remove the fixed upper part
