Central locking problem.
busteredwards
Post by busteredwards »
Hi all, my first post on here :wink: Just bought a 2002 406 HDI Rapier, the central locking aint working right & wonder if any of you fella's can shed some light on the possible problem!
The symptoms are- remote control key not operating the locks..changed battery & tried re-setting it to the car....nothing!
The car only unlocks the drivers door with the key (or the passengers)...still no central locking!
However, if I'm sitting in the car & press the locking button thingy (beside the door opener handle) the central locking will operate!
Any pointers, clues or remedies greatly appreciated. :cry:
Re: Central locking problem.
Welcome mate! :)
Does the LED on the key light up when you press the button? The buttons can fail.
busteredwards
Hi, there isn't an LED on the key. I reckoned it should still trigger the central locking using the key in the door? :?:
Ah ok, didn't realise that!
If it's operating when you trigger it internally there may be a fault with the bsi or water damage to the connectors in the drivers footwell; have a search on bsi reset for starters.
busteredwards
Cheers teamster, I'v just had a look at the reset proceedure & I'll give it a try tomorrow, so fingers crossed! :|
