Passenger-Side Electric Window
Hi all,
My passenger-side electric window has stopped working (bugger). The drivers' window works fine. Also, doesn't matter whether I use my switch for the passenger window or the passenger uses the switch on their side - nothing happens when the switch is used.
I wanted to check if it was simple, like a fuse. But I don't know which fuse it will be.
Can anyone offer any advice on where I should start with this?
Kind regards
Graeme
Re: Passenger-Side Electric Window
Sounds like the motor to me, see if you've got 12v at the motor when you press the button.
I don't own a multimeter :oops:
I will ask around and see if I can borrow one from someone.
coco
Post by coco »
Fit like
Or try a test lamp - any old (good) 12v lamp and a couple of lengths of wire will tell you if you're getting power
2000 406 Coupe 2.0
2004 Berlingo 2.0HDi
