406 buying is this worth it
not sure if this is the right section so please move if wrong place
been after a 406 exec for a long time and just been ofered a cheap one[well i think its cheap i welcome comments]
its blue on a r plate 2.1 diesel 10 mot 3 monthes tax done 150 k looks tidy in blue small laquer peel in places all electrics work apart from heated seat drivers side and the aircon works as well
he says the power steering belt came off and manage to wrap itself round the cam belt [is this possible?] bending the valves and hes had the work done and now the engine runs fine driven it and it goes okay
weve had a chat and its mine for 550 pounds
bad pointsfor me is that it doesnt have a towbar
any comments on anything to watch for on anything mentioned welcome
ps its a saloon
ps its a saloon
Re: 406 buying is this worth it
Seems ok really. Basically with the 2.1 if it sounds well and goes well then all's well
The aux belt can rip through the cambelt cover and cause trouble. I'd maybe get to speak to the place who repaired it if you can to make sure they had the head skimmed after they removed it and that they used a genuine head gasket etc.
At least if it's been doen well then you don't need to get the cambelt done etc (which can cost nearly £200.00).
If you're not sure about anything then leave it (there's loads out there) having said that, £500.00 aint really a big risk these days and if all went belly up you'd probably make the money back by breaking it for spares.
thanks for that so ive bought itWelly wrote:Seems ok really. Basically with the 2.1 if it sounds well and goes well then all's well![]()
faults now found
dodgey fuel flap
cant work out radio
heated seats dont work
oil temp gauge comes on with ignition then doesnt work
- Site Admin & Mad Biker!
That's normal behaviouromega wrote:oil temp gauge comes on with ignition then doesnt work
as in none of them work,or this is the way it works?teamster1975 wrote:That's normal behaviouromega wrote:oil temp gauge comes on with ignition then doesnt work
Yeah, normally it tells you the oil level when you first switch the ignition on, then it acts as the Oil Temp, so it takes a while for the oil to reach it normal temp...teamster1975 wrote:That's normal behaviouromega wrote:oil temp gauge comes on with ignition then doesnt work
You got any pictures of the car mate?
'99 Peugeot 406 1.8 16v LS in Jade Green
- DaiRees
- Site Admin
Yup, what he said
What's dodgy about the fuel flap? Have you seen the clothes peg spring mod?
What can't you work out about the radio?
Heated seats can be repaired, a few people on here have done it.
fuel flap has the common fault from reading on here[flap lever has to be wedged] cant work out where the spring goes have asked on one of the threadsDaiRees wrote:Yup, what he said
think ive got the hang of the radio now but still have not found am
heated seats the switches light up but nothing happens[not to fussed about this at the moment just one of theses jobs to do
Also check the accessory belt tensioner, idler and crankshft pulley. If the crankshaft pulley comes loose or has a nick in it then yum yum belt etc. I had this problem a few months ago when the pulley worked loose, then again when the professional garage who re-attached the pulley forgot to tell me about a nick in it. Munch munch belt, I then replaced pulley, belt, idler and tensioner for good luck.
Hmmmm, straight 6 goodness!
Ah, depends if it's an oil temp gauge or not... A lot of models just have the oil level indicator which works for the first 15s after ignition on, it's only a few that have a temp gauge...teamster1975 wrote:That's normal behaviouromega wrote:oil temp gauge comes on with ignition then doesnt work
Omega, does the gauge have numbers on it, or just a white+red scale?
its meant to read oil temp?Leopold wrote:Yeah, normally it tells you the oil level when you first switch the ignition on, then it acts as the Oil Temp, so it takes a while for the oil to reach it normal temp...teamster1975 wrote:That's normal behaviouromega wrote:oil temp gauge comes on with ignition then doesnt work
mine aint working either then.
lights up at 1st and tells me the level, then just goes off.
at 1st when i bought the car i thought it was to do with the glow plugs, lol.
1997 2.1TD executive estate - mmmm, lovely
Read my reply above - only a few models show oil temperaturetotaleclipse wrote:its meant to read oil temp?
mjb wrote:Ah, depends if it's an oil temp gauge or not... A lot of models just have the oil level indicator which works for the first 15s after ignition on, it's only a few that have a temp gauge...teamster1975 wrote:That's normal behaviouromega wrote:oil temp gauge comes on with ignition then doesnt work
no its not got any numbers on it but says min/max marks and onley comes on when the key is inserted then flicks up to max then stops.did 200 miles in her yesterday and the gauge never moved up
have now found am on the radio
not yet figured the heater /aircon yet,still hoping to get a owners manual from my wanted advert
If it doesn't have any numbers on it, then it's only an oil level gauge, NOT temperature.omega wrote:no its not got any numbers on it but says min/max marks and onley comes on when the key is inserted then flicks up to max then stops
so if its a oil level gauge[as it has no numbers] it only comes on when you start the car then goes of, so it is working as it should then?mjb wrote:If it doesn't have any numbers on it, then it's only an oil level gauge, NOT temperature.omega wrote:no its not got any numbers on it but says min/max marks and onley comes on when the key is inserted then flicks up to max then stops
