Rattle under load
BruceT
Rattle under load
Post by BruceT »
We thought it may have been the water pump, or timing or crankshaft pulley.
Pug specialist fitted a new timing belt kit, new water pump and said the crankshaft pulley is ok and just "tighened" it.
So, why is there still a rattle when accelerating?
Whats weird is it stops at 3000-3200rpm.
Any idea's?
Re: Rattle under load
3,200. Mine does that, it's the injectors apparently.
BruceT
Post by BruceT »
OH right... weird...
My previous Xsara HDi 90 did it too - I'm sure it's not a fault. Did it for the 100,000 miles I drove it without problems.
Doggy's theory is it abandons pre & post injection in favour of emulating a mechanical injection system when under full load.
(Can't explain why it smoothes out at 3000, but then I'm not French) :P
FWIW the 136 doesn't do it, or if it does, the noise gets drowned out by the ecu dumping all the 'excess' boost :x
BruceT
Post by BruceT »
Ah, aslong as its nothing important breaking its all good.
dogslife wrote:(Can't explain why it smoothes out at 3000, but then I'm not French) :P
German? The ecu turns on the third piston in the HP pump at 3,200 rpm.
BruceT
Post by BruceT »
Ah... 3rd Piston on the high pressure pump?
Interesting... 8)
Not really, more moving parts - more to go wrong :(
