I have a Lucas EPIC pump, pump bracket and injectors removed from an R reg 406 2.1td in good working order (was replaced with a 1.9 Bosch from a 405 for running bio / veg).
The injectors will need a clean as they have been kicking around in my toolbox and may have got some cr*p inside them, the car was a bit smokey when pushed hard but was fine when started from cold.
This pump was running on biodiesel for a while (only about 100ltrs) and was courseing some problems wih the tickover but was well flushed out with normal diesel + millers and was running fine for aprox 8,000 miles afterwards.
I'm open to sencable offers and will sell the injectors seperatly if asked.
2.1 Lucas EPIC pum & injectors for sale
406 2.1TD GLX estate
Xantia 1.9TD VSX estate
brew my own biodiesel
