Standard Turbo PSI on HDI 90?????
My HDI 90 is currently runnig 15PSI as i just fitteda boost gauge, the car is totally atandard is this pressure about right????
Re: Standard Turbo PSI on HDI 90?????
Haynes says aprox. 1 bar @ 3000 rpm.
1 bar = 14.7 PSI.
How did you hook up the boost gauge?
Please can you post some pictures engine side?
1 bar = 14.7 PSI.
- swiss
Indeed, and did you run the line through the bulkhead grommet to the passenger footwell?
The man with no car
No i just drilled a new hole in the bulkhead mate, then had a pig of a job trying to find it on the inside
How do you post pictures on here mateBruceT wrote:Haynes says aprox. 1 bar @ 3000 rpm.
1 bar = 14.7 PSI.
Hi,
You can use a free image hosting site such as imageshack or photobucket to upload the pics and then use the web address (URL) to post on here
I just thought if yours is a 2.1 it will be different to my 2.0 HDI mate, have you got a hose coming off your inlet manifold going to your turbo or to your intercoller if you have one???BruceT wrote:Hi,
Hi,
My car is a 2.0 HDi 90 (Not intercooled)
- HimBigChief
I've got the 2.1 mate and there are a few big fat intercooler hoses which I can connect into, but I'd rather connect to a smaller diameter pipe if possible. There's a little pipe on the back of mine with a T piece which has one bit blocked off so I'm going to try it on there first. If it works, bonus, if not I'll just get an adaptor and attach to the intercooler pipe.
