For what it's worth mine does the same Col, i've just got used to punching in the code every time!
God knows what butchery has been carried out on my car in the past, I've had to put loads right!
not that I'm going to do this, but did I read somewhere on this forum that if you unpluggd the keypad when the engine was started, it disabled the immobiliser ?
just curious...
Try it! I know on the 306's if you disconnect the transponder from the ECu when the engines started it unlocks the ECU so you don't need the immob!
