Tyre width 406
Tyre width 406
Hi can anyone tell me the widest tyres i can fit to a 1998 406 its on 195 x 15 inch at the moment but have been offered a set of 215 x 15 inch tyre does anybody know if they will fit without modification to arches etc thanks.
1997 D8 1.8I STILL GOIN!
1996 MERC C200 ONGOIN PROJECT HONEST!
1995 ESCORT DIESEL VAN
2009 DAF XF 105 460BHP
THE PARTY AINT OVER YET !!
- DaiRees
- Site Admin
Re: Tyre width 406
I personally reckon you'd be fine with the width (didn't some of the 16" wheels have 215s as standard?) but you'll need to be careful with the profile. You'd need a 60% profile (215/60R15) to keep a similar rolling circumference as the standard 195/65R15.
Re: Tyre width 406
Will they fit the wheels though?
- HimBigChief
Re: Tyre width 406
Physically fit on the rims? Yes they will. Fit in the arches? Well I run 225/45/17's on the front and 235/45/17's on the rear with only a tiny amount of rub in extreme circumstances (i.e. full steering lock with suspension compressed) and only that is the tyre on the splash guards. So my guess is you would have no adverse affects from fitting say 215/60 tyres as DaiRees pointed out you need to keep the rolling radius the same to keep the speedo reading true(ish).
Re: Tyre width 406
Mine's got 205/60's as standard - can't see 5mm either side making a lot of odds
Re: Tyre width 406
They'll be 6Js though, I'm thinking the 195s are on 5 1/2s
Re: Tyre width 406
i put 205/45/17" on a mk 1 clio with minimal scrubbage and that was only arch liner so i would imagine you would be fine,i also had the same on a 98 306 and the 406 is bigger!!!
Blue 2.0 1997 Petrol Turbo 406 Executive with white leather seats
1 busted clutch rod
1 Easy rider bus ticket!!!!!!!
1 busted clutch rod
Re: Tyre width 406
Thanks to all!Will fit them when i get round to digging it out of the snow,prob end of Jan by the look of it!!!
