centre console
centre console
ok so i have just removed the 2 bolts and 2 screws under the gear gaiter where are the rest to remove the centre console, are the any in the rear ashtray, im confused!
Blue 2.0 1997 Petrol Turbo 406 Executive with white leather seats
1 busted clutch rod
1 Easy rider bus ticket!!!!!!!
1 busted clutch rod
- Captain Jack
Re: centre console
From memory, two on the side under the ashtray, holding the side panels (torx), two bolts behind the front seats at the back on each side under the rear ashtray.. er.. 2 nuts under the front ashtray.
Re: centre console
Thanks, im going to have a good look in the light tomorrow, i did think starting it at 6 was a bit silly!!!
1 busted clutch rod
1 busted clutch rod
