Rear tie bar/rod
JD406
Rear tie bar/rod
Post by JD406 »
What is the rear tie bar/rod?
Ive just been for an MOT and it failed on "Offside rear tie bar/rod has excessive play in a ball joint". Could anyone tell me where its located and possibly a pic of the thing, also where could I get a new one and how much/hard are they to fit?
Cheers
JD
"I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me. Your car...is your story. So don't let someone else write the book." - Moog
jasper5
Re: Rear tie bar/rod
Post by jasper5 »
Have a look here.....viewtopic.php?f=10&t=7376
JD406
Post by JD406 »
Cheers mate
So is it called a rear link arm then, as i dont know where to get one from.
*edit. Is this the part i need http://cgi.ebay.co.uk/Peugeot-406-all-R ... %26ps%3D63
Those are the antirollbar drop links from the look of them, you need the top links.
You can get them from Eurocarparts,
Here's a link to some on ebay.
While you're at it I would check the condition of the drop links and the antirollbar bushes.
jasper5
Post by jasper5 »
JD406 wrote:Cheers mate
Those are the link rods / tie bars pictured in the link I posted, but do check out the anti roll bar link rods which fit vertically,(these have a ball joint at either end) opposite to the ones in my link that fit horizontally.
I thought tie rods were another name for track rods, as in the bits linking the steering rack to the hub carrier? :?
jasper5
Post by jasper5 »
Some people also call them drag links....it all depends on any one person's version of terminology, I have a feeling we went round in circles in answer to the op.
I guess the mot tester knows what he means, maybe the op should ask him.
weejimmy
Post by weejimmy »
if its the wee plastic vertical ones there a pain in the bumholeyo to change if the old ones on it do not have a bit for the spaner to go on, on the opiste side to the nut,
just changed two today that didint. took about half an hour each.
had to pop the ball joint off and get molegrips on the ball itself in the end.
bit of a pain to get into even if they were new. id advise wd40 the day before if poss.
2.1 td exe
totaleclipse
Post by totaleclipse »
these the same thing as rear stibiliser bars?
if soo, my 406 failed for same thing on tuesday.
1997 2.1TD executive estate - mmmm, lovely :)
diesel406
Post by diesel406 »
teamster1975 wrote:You can get them from Eurocarparts,
[url=http://shop.ebay.co.uk/?_from=R40&_trks ... Categories]
Top tip - I jumped onto the eurocarparts website and the link arms are cheaper than GFS even and delivered! :cheesy:
Any comments on getting the bolts loose on the inner body fixing?
Engineer by day - Car mechanic by night - there is a difference!
Now gone to the German Dark Side!!!
At work: http://www.fatigue-expert.com and http://www.xanthusenergy.com
diesel406
Post by diesel406 »
Well the nuts are the killer and I didn't want to destroy the ball joint before being sure to get the inner end off... so I ran out of time and feel I miserable failure! :cry: At least I spotted the piece of metal in my tyre when re-fitting the wheel so I know I need to get this sorted before my next trip on the Motorway! :shock:
Thanks for all the tips chaps! :cheesy:
