Knocking from the frunt
mark21TD
2.2 16v
Post by mark21TD »
My 2.1td has developed a knocking from the frunt'
it's quite a metalic knocking and knocks when I start the engine, when I hit a bump, when I change gear, when I stop the engine
At first I thought it was a ball jouint, but they are both ok, so are the drop links and the anti roll bar bushes.
The gear change is unafected (apart from the knocking),(but it is cable operated).
It's due for it's MOT in less than a month so I need to get it sorted soon, I already have a good list of other work to do
Rear wheel bearing, F/L track rod end, frunt disc's and pads, hand break uneven.
Ooooh, it sounds like a lot of work when you write it down.
406 2.1TD GLX estate
Xantia 1.9TD VSX estate
brew my own biodiesel
HimBigChief
Re: Knocking from the frunt
Post by HimBigChief »
If it's doing it when you start and stop the engine then it's likely to be an engine mount I would have said.
Image Image
Engine mounting and/or your exhaust was fitted by Quick Fick.
mark21TD
2.2 16v
Post by mark21TD »
So if we are thinking engine mount, which one is it most lightly to be ?
Whots the best way of checking them ?
Ps I fit my own exhaust's and keep wellaway from Kwitfit.
poddack
Post by poddack »
On mine I have had trouble with the the rear bottom mount and I am about to replace the top bush.
Hmmmm, straight 6 goodness!
mark21TD
2.2 16v
Post by mark21TD »
I've found the knocking, it's the top engine mount, the vertical one (mushroom jobby) is moveing whare it meats the body.
Looks like it's come unbolted.
Thank good it's not the bottom mount.
mark21TD
2.2 16v
Post by mark21TD »
I've sorted the knocking, I only had to jack the engine up, undo the left hand nut on the mount, then knock the mushroom bit it round with a hammer and long screwdriver untill it was tight, only took 10 mins :cheesy:
The break disc's and pad's are done and so is the track rod end.
I also treated it to a service and some new glow plugs.
BUT, now I have a funny vibration when turning left :frown:
It's only on sharp corners when putting my foot down a bit !
Any ideas guy's.
Well done that man! I had the same on my car about 2 years ago, replaced the drop links & antirollbar bushes before I even thought of looking at the mount :oops:
mark21TD
2.2 16v
Post by mark21TD »
Took it in for the MOT today, even though I hadn't done the wheel bearing (after a closer look it was fine) or the hand break.
It passed with an advise on N/S drop link and an oil leak.
Not so bad realy.
OH and the emmitions were fine with my homebrew biodiesel :mrgreen:
