Newboy needs help - no power!
Locked
loopyloul
Post by loopyloul »
hi to one and all iam loopy and just joined tonight
my 406 is ill had intermitant engine mamagment light which about fifty miles ago be came permanatly on ,switched car off after rundown all fine went back fifteen min later no power not even enough to open centrel locking put on jump but evrything litup but still not turn over? can anyone help newboy cheers :(
TopDonkey
Re: Newboy needs help - no power!
Post by TopDonkey »
Whats your battery voltage before you start cranking, whilst you are cranking, and if it can start, whilst cranking
These 2 or 3 voltages should tell us more
loopyloul
Post by loopyloul »
not sure had full charge sun night put on mon morn still wouldnt start fitted new stop solenoid today still same just flaterns battry as keep craking only crank about 10/15 seconds then reheat but still nothing the previous owner belived in easy start so as ditch attempt tryed still nothing is there way to see if fuel reaching injectors on my trani just crak nut and see but these are high pressure are they not :!:
TopDonkey
Post by TopDonkey »
Is your car an HDI or a TD ?, if its a TD, you are safe to crack the injector feed nut and crank and look for a small flow whilst cranking, if its HDI, you need to be on Peugeot Planet to look at the pressures as its not safe to crack the nut on these
Duplicate topic - see here:
viewtopic.php?f=3&t=9275
Locked
