cold feet
carsten0
cold feet
Post by carsten0 »
I have a 406 HDI from 1999. I can´t seem to get heated air to the feet. Are there anyone whit same problems.
Re: cold feet
Can you feel any air at all coming from the bottom vents?
carsten0
Re: cold feet
Post by carsten0 »
yes,some. But not muts. The heater blower is running
Re: cold feet
Has it always been like this since you had the car?
If so someone may have had the side panels off at some point and not got the ducting pushed all the way on (which is a bit of a fiddle!)
Does the airflow move away from the top vents when you select floor heat?
carsten0
Re: cold feet
Post by carsten0 »
It have always been like this....and yes the air moves away from the top vents, when i select the floor. And more air gets to the feet. But not very much
Re: cold feet
It does sound as though the ducts behind the centre console side panels are detached!
From memory there's a couple of torx screws to remove and then it will come out. Look for a tube behind this which is flared out on one end to meet the side panel. The other end is supposed to slot over the duct behind the radio area.
Re: cold feet
Yes, the "tubing" behind the centre console is an absolute PITA to have on properly... especially if you have lots of wires hanging around back there :supafrisk:
