406 D8 Respray
daddypugwash
406 D8 Respray
Post by daddypugwash »
Hi All,
It's approaching curnch time my 406 GLX. Do I sell it on now or do I keep it for a few more years a runabout. If I decide to keep it then I need to sort out a couple of body work issue, the most problematic of which is some flaking paint around the rear passenger door wheel arch. Chipsaway say I will need a body shop to sort it out and suspect some minor damage wasn't that well repaired a few years back. The rest of the cars has some scratches and scrapes on it so was wondering if anybody knew of a good but cheap body shop around north Hants/Berkshire area; might go for a full respay or just a bit of selected repair work. Thoughts appreciated.
406IT
Re: 406 D8 Respray
Post by 406IT »
Hi - Depending on how much work needed doing and if you have sprayed a car before, i would do it myself - if its only little areas then you might get away with cans - if its large areas or full panels you are going to do its worth using a spraygun - but all depends on how good you are at bodywork - that would be the cheaper option - and also if you have access to a garage as spraying outside this time of year is a no go. - post some pics of the car if you can and i'm sure some more guys will give you their thoughts.. - if you ae going to be putting in to a garage - then if you have a cheap respray it will only last a few years before it starts flaking again - or expensive if the prep done properly - local work if not that much i think could be cheaper option.
1997 406 1.9TD Estate
1989 BMW 735iSE Auto
2002 Mazda Premacy Sport
bangernom1cs
Re: 406 D8 Respray
Post by bangernom1cs »
If you take the time and patience then cans can work perfectly.
Even for whole panels! If you look through my posts on here you'll see how we repaired a considerable
dent in the rear quarter on my D8.
The cans came from Halfords (£20 ish )who do a perfect colour matching service.
viewtopic.php?f=2&t=6999
T
