Weird pad wear?
stevenlizuk
Weird pad wear?
Post by stevenlizuk »
Helo all,
Just put new pads and discs on the front of the Funbus and the wear on them was a bit strange to say the least.
Three of the four pads were left with about 5mm of friction material on them but the outboard offside pad only had about 1mm left on it.
The sliders are free and the piston returned no bother at all.
Any clues?
Enjoying having working brakes again, discs were a bit thin.
Steve
She cannae take it captain!
Proud owner of the Funbus 98 2.1td estate being reborn £70 at a time.
Still need new back-plates.
Re: Weird pad wear?
I don't understand why it happens, but I've had a few cars, with sliding calipers, that I've had long enough to do multiple pad changes. Often seen uneven pad wear, (but strangely not the same pad each time)!???
Doggy's theory of pad wear states the following:
1). Pads can last for over 50k miles of normal use, but unless checked immediately beforehand will wear out during 300 holiday miles.
2). The rate of pad wear increases exponentially as your MOT approaches.
3). In any set of pads, the wear sensors are always fitted to the pad(s) that last longest.
HTH
stevenlizuk
Re: Weird pad wear?
A failed spring took out the wiring for the pad wear sensor on that side is that an MOT failure?
406IT
Re: Weird pad wear?
Post by 406IT »
Hi - The Pad sensors are not MOT requirement - they are only there for your info - they are not necessary - I dont know about peugeot but on BMW if the wires are not used / cut they will always display a message to say the pads are worn down when thet are not unless the sensors are fitted - But i just shorted out the sensor and dont get the message anymore on my BMW until i can get the sensor wires..
1997 406 1.9TD Estate
1989 BMW 735iSE Auto
2002 Mazda Premacy Sport
robb
Re: Weird pad wear?
Post by robb »
My mate had the same problem on his Hyundai santa fe 27000 on the clock had to change his pads because of uneven wear . I did mention to him that towing a caravan every weekend could be putting unnecessary strain on the brakes :idea: ?
